Results 1 to 10 of 11
Thread: 4" rear drop, axle to frame distance...
    I not sure but after doing my drop on the rear of the truck (with shackles and hangers) my truck seems lower than 4".
    I only have 2 1/2" between the frame and the axle, is this normal? I can barely put any weight in my truck and it bottoms out. Also with big bumps in the road it smacks the frame hard.
    There doesn't even seem to be enough room to install helper bags.
    I really don't want to c-notch the frame, but in the past I've ridden other trucks with just a 2/4 drop and have never felt anything like this before.
    Yes I do have drop shocks, before anyone asks
    05 Gmc Sierra RCSB 5.3 - Vortech V2 Intercooled, BBK 80mm TB, Edlebrock shorties, Custom built 3" Catback W/Borla XR-1, GM Built HD 4l60e w/ transgo shift kit, power servo and corvette shift pin, Yank 2600 Stall TC, Belltech 2/4 drop, Doetsch Shocks, 3.73 gears w/yukon lsd
    not being a smartass but are your shocks right side up?
    Apr 2006
    Bellevue, Nebraska
    Mine is the same way. I have right about 2" between frame and axle. I have a c-notch but I haven't had the time to install it. I just try to go slow over bumps. But it is extremely annoying/painful on long road trips when I hit bump after bump. Dips in the road are bad too!
    Quote Originally Posted by AFSP1211 View Post
    yes it's annoying... There is one dip on the freeway on the way home from work that slams the frame every day.
    I got a couple inches, mines never bottomed out. And it's not babied. Stock shocks though
    Apr 2006
    Bellevue, Nebraska
    Quote Originally Posted by Boost05 View Post
    My frame has started to bend a little bit. It pinches my rear sway bar too. I should prob go ahead notch mine before I get the urge to sell the notches.
    Quote Originally Posted by Ls2Aero View Post
    Shaft up, same way the old ones came off... why do you ask?
    Cause my buddy had his upside down when first did his drop and it bottomed out like crazy...
    they make a bump stop for dropped trucks, doesnt really do anything but stop the metal on metal contact, mine is the same way with a 2/4 put caltracs on and it doesnt budge, i can jump up and down on the bed and it moves maybe an inch.
    I would say try a set of stock length shocks and see if that helps....I plan on keeping stock lengths when I do my 2/4 also.
