Results 1 to 7 of 7
Thread: LH8 Hummer H3 pan in OBS 88-98 C1500
    Sep 2011
    I've been searching all morning trying to find someone who has installed a LH8 oil pan in an 88-98 truck. My truck is lowered so I don't want an oil pan that hangs below the crossmember at all. I've found that the Gen 3/4 truck oil pan hangs too low and the F-Body oil pan gives "Plenty" of clearance. Does that mean the LH8 pan is just right? From a few measurement sources it seems the LH8 pan is only about 1/2" to 3/4" shorter. Is that enough?
    Mike
    set it in and see man, otherwise why not just run an fbody pan.
    Birmingham, AL
    i saw a link the other day somewhere that had pictures and dimensions of every LSx oil pan... dont have a clue where tho! haha
    hope that helps!
    but really, maybe someone else iwll remember where that was, it was pretty useful
    01 Silverado
    Feb 2011
    Barnwell, SC
    I know I posted a link in my garage.
    Round Rock, TX
    it will fit no problem.. I'm pretty sure the standard truck pan hangs 1 1/4" below the crossmember and the H3 pan is shorter than the truck pan. Fbody pan works great but you have to move the motor all the way back in the engine compartment to clear. I currently run a modified G8 pan due to the capacity, it holds right at 9qts..
    Feb 2011
    Barnwell, SC
    99 Silverado 4.8l : Soon to be 80E swapped, then 6.0 swapped, ......
    05 Yukon Denali 6.0l : Nelson Performance Tune, ......
    8X S10 Blazer on a 8X 3/4 ton frame : 5.3l swapped, Nelson Performance tune, Schoenfeld LT's, 226/226 .598/.598 112, TH350, planetary doubler, NP 205, locker, spool, 38's, ......
    Quote Originally Posted by blacksss46 View Post
    couldn't agree more. its like boobs you'll get a C and end up wanting a D...just get the bigger one and be happy
    GM makes a kit....LS wet sump RWD Oil Pan Kit-chevelle, camaro, nova SKU: 19212593....got mine from a GM dealer.....I believe it is the hummer pan incl. pan, windage tray, pickup tube, gasket, bolts and dipstick....I paid $153 + tax.....hangs about flush with X member in my '93...with stock clamshell mounts.....
    '93 Chevy Sport... LS2...T56 Magnum..."Red Rider" under construction.........
