Results 1 to 8 of 8
Thread: What Transfer case to use in 1994 OBS 6.0 4L80E Swap
    Jun 2009
    Caledonia, MI
    I was wondering what the possibilities are for hooking up transfer cases to the 4l80e. A 241C transfer case is whats in my truck right now (manual shift). What wondering if that will bolt right up to the 4L80E without a problem. If not, whats my other options. Thanks!
    will need to change to 32 spline input on the 241
    Feb 2011
    Barnwell, SC
    Check out advance adapters. They are pricey, but will have a solution.
    Jun 2009
    Caledonia, MI
    is there any other options. what if i used the t-case out of the donor truck, what would have i have to do
    what do you have against swapping inputs? this is gonna be cheapest/easiest method imo.
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by slow600 View Post
    Is it that easy? I thought there was more involved. If thats all I need to do if swap the input shafts, then count me in!
    Monett Mo
    Yep its real easy as long as you can find the right input shaft. And make sure you have a good set of snap ring pliers. I think it took me about an hour to change mine out. Also when you put it back in ur truck the linkage for the shifter will have to be extended if you didn't already know.
    Mar 2007
    Quote Originally Posted by 92 6.0 View Post
    It is only me or My np241c was a bolt on in My 80e swap.
    My truck is 2002 4x4 rcsb.
    The np241c holds a lot of power.
