Results 1 to 10 of 18
Thread: injector upgrade needed for cam??
    Apr 2011
    Is an injector upgrade needed for a cam swap??
    Cam spec:
    218/230
    525/542
    112 lsa
    Ponca City
    Vague info. But doubt it
    Slowest in Oklahoma...
    Jan 2011
    Mcalester,okla.
    +1 which engine,what year, do u have stock fuel pump,etc. but even if everything stock, pump etc. should b fine, just let ur tuner know all ur specs
    Apr 2011
    My bad.. well the shop where I get my tune from said that if I do the cam swap.. then I will need better injectors...I've seen a lot of other cam swap threads tht don't say anything about changing injectors.. so I got confused :/
    Apr 2011
    04 Silverado 5.3.. fuel system is stock
    Ponca City
    What mods and such. Give us a run down so we can help. A cam only no need but depending on what bolt ons and such things can change
    Apr 2011
    2004 Silverado 5.3.. k&n intake, pacesetter longtubes and 3" y pipe , magnaflow 2.5" 1 in 2 out,efans,vette servo and tune. Thanks guys
    Jan 2011
    Mcalester,okla.
    I would say ur fine that's a pretty mild cam and good bolt ons don't think any need for bigger injectors. One way to find out is cam it. Then scan it to check ur injector values
    Apr 2011
    Ok .. how will my truck run without a tune for the cam? I kno I won't get the full benefit till I get the retune but I'm asking because Im doin the swap with some buddies and it mite be a day or 2 at most till it sees my tuner
    Sep 2010
    McPherson KS
    It won't want to idle very well on its own, and you'll be two footing it at every light, but it should run well enough to get you around for a day or two. Just don't try to lay into it at all before you get the tune.
