Results 1 to 9 of 9
Thread: 4.3l to 6.0
    Dec 2011
    Arizona
    4.3l to 6.0
    I am looking to swap a LQ9 into my 03 silverado 1500 5 spd short bed does anyone know where i can pickup a complete swap (wire harness, PCM) and what would be a good option for a trans that is still manual 5spd 6spd either is fine. also any pointers for my future project are greatly appreciated
    03 is a pain in the ass year. Go to a junkyard, find another 03. You will need, engine, harness, accessory drive, all hoses, mounts (frame side), gas pedal, TAC module, harness from between pedal to TAC module. You have to go DBW, do not try to keep DBC. V6 PCM will work, just needs to be reprogrammed.
    I swapped my '06 the stock 5speed is holding fine for now. Best option is a T-56 from an F-Body or GTO. There is quite a few threads on this already.
    Dec 2011
    Arizona
    i have been looking through here and PT.net have found alot of useful info im still cloudy on the fuel lines alot of ppl just say to buy some flex hose
    Dec 2011
    Arizona
    also what will it take to install the T56 and will there be any problems
    Since you already have a 5 speed the t56 is just a simple trans swap & a new hole in the floor for the shifter, unless you get a relocation kit that moves it almost as far forward as factory.
    My fuel lines (well line, my trucks returnless) I cut it just before it bends at the top of the firewall and put a compression fitting on it. Then ran a braided stainless -6 line to the fuel rail. Your truck is a return setup. 3/8 supply, 5/16 return.
    Ottawa, ON
    I did a LS6 swap in my 2000 with the 5 speed, still not complete yet due to starter clearance issues. Gonna finish it in the spring. I used a 2001 2wd truck harness, couldn't find a 5 speed harness so I just got the auto. Only thing I had to do was jump the 2 wires at the park neutral switch connector so it'd start with the key.
