Results 1 to 10 of 17
Thread: 4l80e broken bellhousing
    Dec 2009
    Corona, CA
    4l80e broken cracked bellhousing
    So I finally got around to removing my 80e. Anybody have a clue how this would happen? My best guess is it happened when my drive shaft blew. Idk but it's frusterating as hell.
    Next, with no relation to the above statement. I removed the trans fluid that was in the pan and there was a crap load of sediment left in there. I rolled it up ina ball the size of quarter. I tried to see if it was magnetic but it wasn't. Clutches i'm guessing.
    2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
    Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
    Nov 2011
    Arlington, Tx
    Quote Originally Posted by Chris092183 View Post
    When I blewy driveshaft up that's exactly what happened to mine. The bellhousing was in pieces AND it broke the starter mount off of the block life sucked that day.
    Sep 2010
    N FL
    Quote Originally Posted by LS3CC View Post
    GOT D*MN!! thats suks a BIG one!
    Mar 2007
    That sounds real bad. let me guess....
    You blew your aluminum driveshaft right?
    That will explain the allergic reaction you have to aluminum now days. !!!!!
    Nov 2011
    Arlington, Tx
    Haha yes it did. Makes things even better, it was my 6.2 :/
    Luckily I saved the block and tigged it back together. It's in my truck now with no issues luckily.
    Mar 2007
    blowing driveshafts goes from just hitting the gas tank to split the engine block. So yes, your 80e was torn by that.
    I got mine torn along with my transfercase when my steel DS was twisted and the crossjoint in the rear gave up.
    As for the gum inside, nothing a refreshing build won't cure.
    Good luck in your repairs.
    Nov 2011
    Arlington, Tx
    Haha, you nailed it! I hate aluminumn driveshafts :/ but I was asking for it by putting a 6.2 in it
    I'd like to compare the size of your stock DS and mine. Mine's aluminum too, but it seems to be HUGE compared to most I've seen...
    Nov 2011
    Arlington, Tx
    Lol. Your not the only one with a huge aluminum driveshaft, or a huge wiener for that matter. Haha. I think the stock aluminum driveshafts are 5 inches, don't quote me in that one though.
    That sounds right. When I first saw the one in my CCSB I was surprised.
