Results 1 to 10 of 16
Thread: Help with ARP bolts please
    Jun 2009
    Youngsville, LA
    If I install 6.0 .heads on my 5.3, do I oder bolts for the 6.0 or 5.3, or are they the same? I know it may seem like a dumb question but its something I didn't know so I figured I would ask.
    2011 Chevy crew cab 5.3
    2013 Chevy crew cab 5.3
    Pittsburgh, PA
    6.0 heads on a 5.3 is a bad decision but if your going to go thru with it, then get the bolts that match that year block you have
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Ponca City
    x10
    Slowest in Oklahoma...
    Jun 2009
    Youngsville, LA
    May I ask why? I kinda of thought it was a common thing with boosted 5.3's. I guess I'm still learning on the LS engines, most of my experience is on big nitrous fords. But don't the 6.0 heads lower the compression a reasonable amount, therefore being better for high hp turbo engines?
    I would like to know why you say it is a bad idea, I'm all up for learning anything new with these engines.
    Ponca City
    the cc of the 6.0 heads will drop you quite a bit...but who says you need low compression to be boosted...
    Jun 2009
    Youngsville, LA
    I guess that is the old school way of thinking.
    Ponca City
    I think if your going for super high hp lower is better. But it'll be a turd outa boost. There's alot to read on this. I did a ton and I stayed around 10.6:1 for my setup
