Results 1 to 10 of 26
Thread: built 4l60e or 4l80 swap?
    verona, virgina
    Going to try and replace my stock trans sometime in 2012 in my yukon xl and debating on what to go with mainly cause of the weight of this pig. Ive got 103k on the clock now with full boltons except efans and a stall. Ill be tossing a cam in sometime in the spring if everything goes as planned. i dd my yukon most of the time we take it on trips drive on the beach do very little towing but ya never know it may change if i find a car trailer cheap but even then i wouldnt tow often and both my cars that i would ever tow are in the 3000-3500lb range. there is a possibility of a 6.0 swap in the future when the 5.3 pukes. So with most likely keeping it in the sub 400whp range but weighing 6000lbs would a 60 hold up over time with my beatings and very light towing? dont mind my sig pic lol i rarely if ever play from a dig with this tank anymore and dont try to spin tires. Im mainly planing ahead since i know my 60 is on borrowed time and dont wanna be without it when i need it.
    03 yukon xl:intake, longtubes ory,performabuilt lvl2,circle D 278,tune, tint, lt1 fans
    92 z28: lb9 air foil vette servo magnaflow catback adjustable pan hard rod Lcas lcarbs
    86 trans am: lm7 hot cam th350 3500 stall
    Nov 2011
    Arlington, Tx
    4l80e, I would suggest one over a 60e anyday.
    southside VA
    Do a well built 60e. I wouldn't do an 80e unless you plan on making alot of power ie fi nitrous. Build it with the right parts and you'll be good. Nothing lasts forever though especially making 4-500 HP but I would still choose the 60e.
    verona, virgina
    If it was 2wd I prob go towards a 80e more since then I wouldn't have to deal with the transfer case. Just tryin to weigh my options.
    Nov 2011
    Arlington, Tx
    Didn't realize you were 4wd. I just have never had good luck with a 60e.
    Ponca City
    80e swaps have gotten simple. A stock or mild 80 will hold a ton. You can rewire for less than $10 and build your own crossmember. They make an adapter for your t case. Little drive shaft adjustments. I'm like ls3cc iv had crap luck outa 60s. If you decide to do a 60 get a name brand company built one. Stay away from everyday stock rebuilders.
    Slowest in Oklahoma...
    80e, even stock ones are better than a built 60 IMO, i ran a bone stock 80 in mine forever, and eventually ill convert this awd 65 to an 80e im sure, time will tell
    verona, virgina
    The crossmember is no big deal but the t case is what I'm worried about. What are the ratios in a 80 vs. 60 in know the first gear in the 60e is like 3.06 or 3.05 and is is like .72 or something. What would be a good price on a stock 80e? Plus what years to look for ect? I've looked into the swap sticky but again I'm 4x4....
    Dec 2010
    If you are under 400 rwhp I think a PROPER 60E build is fine, but A proper 60E build can easily run $1000 in just parts, then you need to find a builder to assemble it correctly with shift firmness moderated perfectly.
    Keep in mid most 60e's brake during hard 1-2 shifts if you are going to run a 60e, keep the 1-2 shift tame, only go with the corvette servo, the billets hit hard and are only intended for high stalled/all out race applications.
    Nov 2011
    Arlington, Tx
    By the time you spend 1000 or more on a 60e you could go get a low mileage 80e for 850 with a warranty
