Results 1 to 2 of 2
Thread: Injector pigtail ?s
    Aug 2011
    Injector pigtail ?s
    Hey all, doin a 5.3 swap into an 88 k1500. My wire harness is from a 00 camaro. I'm runnin a truck manifold/injectors. I have the pigtails that hook into the truck injectors. How do I wire them to my camaro harness. I know it's a simple 2 wire hookup but don't know which wire goes where. All the wires are different colors. Any help is appreciated. Thanks.
    It should be pretty easy because all the truck injector connectors should have a pink wire which is your switch power and whatever color the other wire is is your pcm control wire. just make sure that you have the injector driver wire going to the approptiate injector.
