Results 1 to 10 of 11
Thread: Pros and Cons of z06 cam in a 5.3
    Aug 2011
    I have a high mileage 2000 Silverado 5.3 wanted to know if putting a ls6 cam would be a good idea? Like what power gains if any and what fuel mileage decrease. Also do i need to run a stall?
    Nov 2010
    Durant, Ok
    It would work fine. Fuel mileage probably around the same, power gains maybe notable on the Dyno, you don't have to run a stall. I think you will need the ls6 springs tho, someone correct me if I'm wrong
    Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
    2000 z28 a4 longtubes, true duals, ported throttle body, ls6 intake, slp lid (lost in divorce lol)
    79 camaro small block street car 11.60 @ 116 (sold)
    pro's:
    cheap cheap cheap cam and ls6 valve springs can be had for around 200-250
    fuel mileage is around the same (as scarybowtie stated)
    more nut in the 3000+ rpm territory
    no tuning needed to get the truck to run and drive
    con's:
    not the best cam to go with if you want to make power
    Dec 2008
    South Carolina
    kills low end power
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Aug 2011
    All i have done now is hp tuner CAI and flowmaster with cat delete so any cam recommendation would be great. Keep in mind it is my daily driver
    just cause its a DD doesnt mean you gotta get a small cam, just throwin that out there.
    I drive mine 44 miles each way to work. 5 days a week. And I've got a 219/230 .604/.609 117+2lsa cam. Oh and I get 16mpg with a pretty bad exhaust leak that's making it run real rich.
    dont you have like a million miles too.
    Spring, TX
    You need to explain the reason for that split to me. I'm still learning cams.
    ^Ricky's Sweet PS Skilz
    Arizona/Utah
    He has like 230+k miles. The split is to cope with the boost and/or spray he plans to add at some point if I remember right.
