Results 1 to 10 of 44
Thread: 4L80e boom and has no gears
    Ponca City
    Went to the track and made some passes and had no issues. On the last pass made it about half way and the truck made a funny noise and I lost all gears, forward/reverse/everything except park. Me and others assumed the input shaft had broken. Got the tranny out of the truck and it's not broken. I can turn the input shaft by hand and it will try to turn the output shaft and vise versa. Pulled the pan and it's clean. Been reading about converters breaking and most say the verter will rattle if shook... Mine rattles alot. The tranny is an FLT and verter is a circle d 4200. Any ideas on what gave up??
    Slowest in Oklahoma...
    Mar 2006
    Mesquite
    Rear end?
    If the input or output shaft were broken, park would not work. My guess is pump or converter if nothing works but park does. Can't think of anything else.
    Dec 2003
    Pull the rear end cover and see what you find.
    2000 RCSB forged ls1, 4l80e, t-76
    10.93@124 1.58 60'
    Park generally doesn't work with a blown rear axle either.....unless you weak blew it
    Ponca City
    Park works and the rearend is fine. Outputshaft feels fine and so does input shaft
    +1 pull off one of the atf cooler and rev the motor
    Ponca City
    The tranny is already out of the truck
    take the pump apart and look at the vains
    i hate to disagree, but on my FLT lvl3, i blew both the input and output shafts at different times.. both times i had park, with the output shaft, i had reverse.
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
