Thread: what parts are interchangeable between ls motors?
    hey guys i got a 2002 2500hd 6.0 project truck that i need parts for. I want to order parts from ebay and didnt know if i could order parts from ls1's or other motors. i can find these parts cheaper and easier on their and not sure if its because they are more common to search for and buy or if its different parts.
    Heres a list of parts i need.
    Mass Air sensor - ive seen some bigger "performance" ones will those work or actually add hp?
    Crank sensor
    cam sensor
    spark plugs
    coil packs
    plug wires
    throttle body
    Also i need steering parts, tie rods ball joints, ect. are the parts for 2500's and 2500hd's the same? big price diff online.
    Mass Air sensor - stick with a stock oem unit from/for your truck
    Crank sensor-not sure
    cam sensor-not sure
    spark plugs-just go to napa for them and save on shipping
    coil packs-not sure
    plug wires-4.8/5.3/6.0 are all the same
    throttle body- 3 bolt from a 4.8/5.3/6.0(dont know if you have a cable unit or dbw)
    Dec 2009
    houston tx
    Quote Originally Posted by beingblueeyes View Post
    Crank sensor-same
    cam sensor-same
    spark plugs- ngk 3951
    coil packs- a little bigger on ls1s but they are about the same
    throttle body- 3 bolt from a 4.8/5.3/5.7/6.0 are all the same 99-2002
    fixed for u
