Results 1 to 9 of 9
Thread: 160* thermostat
    The Garage
    160* thermostat
    Where can I buy a 160* thermostat for my 06' silverado? I tried buying one from summit but the damn thing doesn't fit. Suggestions?
    The Garage
    Pittsburgh, PA
    something else you can do that does work. You can drill several small holes in the factory Stat. the more holes the cooler the motor will run. Found out 4 holes netted 170* temps on a 408
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    The Garage
    Now THAT is good to know. I may just do that. Just to be sure tho, which disk do I drill on the stat? The side that inserts into the thermostat housing or the side that inserts into the water pump. Thanks a ton Quik
    So Cal
    Hey jet what did you end up going with? purchasing one or drilling the holes? i just bought me a Lingenfelter t stat as well but it didnt fit cuz i had no clue i had a newer water pump with a 2 piece t stat, very easy to do your self to, its just really messy
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Dec 2011
    I just ordered a 160 thermostat will I need to get a tune to get it run at 160
    Apr 2010
    Stigler Oklahoma
    Quote Originally Posted by Cccrst2008 View Post
    No
    Quote Originally Posted by jakedewey View Post
    No
    The fans will act a little funny if you don't have them changed in the tune.
    Dec 2011
    What about fuel mileage will it drop or should I just get a tune and up the timing more since lt will be running cooler
