Results 1 to 10 of 18
Thread: wanna go boosted
    Feb 2010
    wanna go boosted
    i want to turbo my truck but i dont know the best way to go it. i want to run 10-12 with a stock bottem end. right now i have a 5.3 with p&p heads and cam to match 219-227 .607-.613, tbss intake, heads have 30 thousands shaved off. or should i get rid of the 5.3 and go with a 6.0 with a boost cam. i kinda want to keep the 5.3 but i dont know how much boost it can handle being higher compression. also i would like to know if a stall is nessary with boost, right now i have a 3200 but its in a 60 and im going 80
    Hand p&p heads, 219-227 .607 .613, pacesetter, tbss intake, 92mm t-body, cai, e-fans, 14 bolt, 4.56, true trac, pi 2800, 33's, 4l80e built by me
    In the makin
    Boost.
    Jun 2004
    george west texas
    where are you from
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Feb 2010
    michigan
    In the makin
    Boost.
    Oct 2006
    Wichita Falls Tx.
    Go turbo now and upgrade engine later. .
    Stall is matched to cam more then turbo or boost.
    A boosted,cammed 5.3L will handle a n/a cammed 6,0L .
    We can build you a nice turbo kit with intercooler, let me know if I can help your build out.
    Jul 2011
    S.A 210
    boosted and cammed 5.3 sounds pretty goOD to me.... i think a 3200 stall should be fine.....unless u go BIG turbo....
    Feb 2010
    i kinda want to get a way from using a stall, if i get a boost cam are stalls recommended with them.
    In the makin
    Boost.
    Quote Originally Posted by 02chevyls1 View Post
    Depends how big it is. I wouldn't shy away from a stall. They're going to give you a huge SOTP gain.
    Boost is where its at.. But can destroy a stock motor quick if your not careful! But man its sooooo funn!! LMAO
