I got my headers on but need to know what size pipe plug or bolt you guys are using to plug the egr tube on the passengerside header?
Ace- the helpful place... ? idk the size but you can probably find a bold there that will work![]()
Built 2 Run! 6XX HP/ 6XX TQ
if i remember right I used an 1/8" NPT steel pipe plug
2003 GMC K1500 ECSB running an Iron 383 Stroker ......
thanks i was gona just pick one up from work tonight but i forgot before i left.
03 yukon xl:intake, longtubes ory,performabuilt lvl2,circle D 278,tune, tint, lt1 fans
92 z28: lb9 air foil vette servo magnaflow catback adjustable pan hard rod Lcas lcarbs
86 trans am: lm7 hot cam th350 3500 stall
Where can I get a block-off plate for the EGR hook-up for the passenger side header?
* 2004 Chevrolet CCSB Z-71 5.3L * G80, 3.73's * Black Bear Autocal 91 oct tune * Magnaflow 3" SI/SO 14" case * Airaid M.I.T. * OEM airbox with open air modification * Color matched grille & lower valence * Blackened Tail Lights * SuperBright LEDs in brake lights & reverse lights *
In the garage to be installed: 799 heads, Dyna-Tech long tube headers, Corvette servo, 2" lowering shackles, 2wd u-bolts & bumpstops
