Results 1 to 7 of 7
Thread: 07 valvetrain knock
    Mar 2007
    07 valvetrain knock
    bought an 07 1/2 ton crew cab new body style yesterday. throwing a PO304 Cylinder 4 misfire. horrific knocking noise is coming from the head/valvecover area. the guy i bought it from said the chevy dealer told him it was a lifter bad. any guesses/suggestions. i have searched all over this site and others and not finding much. i will be tearing into it this weekend and just thought i would see if anyone can guess what it is before i open it up. the truck is 4x4 with 125K. still holds 45psi oil pressure at stop sign and does not have any vibration or balance issues
    1979 K30 straight wheel 4X4. 04 6.0 LQ4, 4L80e, NP205, 60 front, 14 bolt Disc Brake rear
    Sounds like one of the DOD lifters failed. If you plan on keeping DOD, replace with a DOD lifter. If not, have DOD turned off in the tune and replace with ls7 lifters.
    Mar 2007
    replaced it with dod lifter, ran it for 2-3 minutes and ran good and quiet. changed oil and started it back up. ran for another 5 minutes and it did it again. same lifter just as loud. thanks for the reply pl4boy. any suggestions. i live just south of the kc area and i called a shop around here who does ls motor work(mainly car) and they suggested the o-ring on the bottom of the valley cover could be causing a lack of oil pressure. any help would be provided
    What's the rocker like? How about the pushrod? Bent maybe?
    Mar 2007
    rocker and pushrod both looked good when i had it apart
    Feb 2008
    Kanada
    Have you found the problem yet?
