Results 1 to 10 of 10
Thread: Brake upgrade.
    Jan 2011
    Easton PA
    Brake upgrade.
    Trying to improve on the standard crummy brakes that are on my 03 Silveradowith the 5.3. Nothing wrong mechanically, just they have been garbage from the day it was new. Brake pedal spongieness has got to go.
    Been told that I can upgrade to a newer model Vacumm system and DON'T really want to go with the Hydralic set up at this time.
    The local recycler is asking me a few questions I can't answer.
    Off an 05 Silverado he is asking me the RPO codes.
    Vaccum JC4, JF3, or JF7.
    Anyone know which one is the better of the bunch???
    Which 1 would be a direct fit replacement???
    Thanks
    Paul K.
    Easton Pa
    03 Victory Red Silverado Z71 w.135,xxx & counting. x-cab 4x4 w/3"body lift rhino lining bed mods to come
    07 Saturn Aura XR rims tint interior mods
    RIP. '95 Chevy COPrice Black,Black,Black w LT-1 full Impala Interior, motor/drivetrain/suspension/exterior mods
    Broken Bow, OK
    You can put 05 front brakes on. All you need is the calipers, pads and rotors. Your existing lines will work, and the calipers bolt right up to the spindles.
    hydroboost is the way to go. Anything else is a waste of time unless you plan to hydroboost later.
    +1,000,000,000,000
    Jan 2011
    Easton PA
    Hydraboost is what I want to do, however cost and primarily time is what I have to deal with.
    Guess no one really knows the difference with the RPO codes I posted earlier?
    Will look in the performance mods section and read up on it a bit more.
    Paul K.
    Easton Pa
    Feb 2008
    Mass
    Id love to do hydroboost but couldnt afford it at the time, might sometime soon but i did steel braided lines and it got rid of the spongyness quite a bit, im glad i did it.
    2000 Silverado Ecsb 5.3 Z71. Work in progress...
    Do this.
    there is a thread...that i started...in the performance mods section. may want to take a look at it.
    Stainless braided brake lines are a good addition to. If you want larger rotors Quik has some in the for sale section at a good price. OR did the last time I looked.
