Thread: will it work???
    May 2011
    Corpus Christi, Texas
    will it work???
    my heads are decked .025" and i believe i found the new cam i am wanting to get..
    the 228-228 has a valve lift of .588 will i have enough clearance in between my valves and pistons???
    could i go bigger and still be safe, if so how much bigger?
    May 2011
    anyone???
    It depends on the valve events. Chances are you'll be fine though. Clay the pistons, assemble motor, turn it over a few times pull the head and check the clay.
    I have stock heads with a .609/.604 lift cam and its just fine.
    May 2011
    ok... i think i know what ill do.
    you'll be fine
    Simple: 408 on steroids!
    single digits coming soon!
