Results 1 to 10 of 10
Thread: ecm mounting?
    Jul 2009
    Oklahoma City
    ecm mounting?
    how did u guys mount the ecm? i got a 81 chevy with a 2002 5.3
    I used the 96-2000 vortec 5.7 mounting brackets.
    works ok
    Broken Bow, OK
    I used that same bracket from a 96, but mounted it behind the glovebox in a 70 model.
    best bracket i've used is the '02 corvette bracket, mounts almost anywhere and is very secure.
    You wouldn't happen to have a p/n or pic, would you?
    I might need to move my ecm in the future...
    TIA farmtruc
    May 2007
    Oak Forest, Illinois
    The PCM bracket from an 01 and up S10, Jimmy, Bravada mounts flat and works very well. It mounts perfectly to a flat surface.
    Jeff
