Results 1 to 10 of 28
Thread: g80 is done!!!!! Suggestions on good replacement!
    Rear end is done in my truck. 05' z71 5.3. Question is what to replace with? I've been wanting to change ratios. Running 3.42 now. Cam, longtubes, stall and tune coming soon. I'm thinking 4.10's ! What type rear is good and can I run 4.10 in rear and leave fronts 3.42 as long as I don't use 4wd. Eventually going to do both as finances permit. I'm also on the stock 17's. On the last track day I ran 15.0 at 93 with current setup. Thanks
    the whole forum will say tru-trac. 4.10's if your not on highway much. 3.73s if you run the interstate.
    Psalms 144:1
    Si vis pacem, para bellum
    Quote Originally Posted by kyhunter89 View Post
    x1,000,000
    Oolitic In
    but wouldnt see that big of a diff from 3.42 to 3.73 would ya
    So can I run the 4.10's outback and leave front alone? Just don't use 4wd on any hard surface.
    Quote Originally Posted by l33z71 View Post
    im not sure how that would work, even if all 4 wheels are spinning the computer would still see 2 different speeds for the front and back
