Results 1 to 10 of 40
Thread: Low end sucks!!!!
    Apr 2010
    Hell Paso Texaz
    Low end sucks!!!!
    I have a 4,8 nd my low end just blows. First off all, its not a posi (Get it a Z71 w/ no posi?!?!?) Ok so i was off roading by myself.(4HI) Then half way up a steep hill the stupid truck just crawls to to a stop. It just stays there it humms. It doesnt move at all!!! I shift to 4LO and the tires just spin, is this normal? I already have a tune, feels a little better but it really screams at mid to top end. How can i get a little more push at Low RPM. and what gears do you guys recommend for an daily driver? Has 3.73 from factory in august ill be adding LT headers and CAI oh and a Auburn Posi system.
    03 Chev Z71 4.8. Need quite a bit to go. NPT BABY!!!
    Jun 2010
    West Texas
    If you dont mind sacrificing mileage for power, 4.10's with a lets say 2800 stall and you should be good.
    RUN WAT U BRUNG!!!!
    Dec 2008
    san antonio TX
    what size tires do you have?
    Arizona/Utah
    Get a higher stall for sure best bang for your buck (circle D stall under 400$)and a rear locker would be good. If you daily drive it the 3.73's are a happy medium although 4.10's would give you most kick down low.
    Apr 2010
    Hell Paso Texaz
    Quote Originally Posted by lechez71 View Post
    33's
    soon to be 35's or 37's when lift kit is added
    Racoon Twp., PA
    How big a hill?
    I had 35's on a 4.8 with stock 3.42's and never had an issue. But never got too crusty with it.
    Please don't do 37's. Even 35's are a bit too big for a 6'' lift and rub (6+3 BL looks bewbs). Stay with the 33. Go 4.56. It will be a good gear if you do 35's eventually as well. Bigger stall will help a ton as well.
    Hit up Ron for gears. He is a dealer on here and has awesome deals, great service, and awesome turn around time.
    2013 CC 5.3
    81 C10 LS1 project
    dont messs around put 4.56s in there with a 3200+stall
    Dec 2008
    san antonio TX
    Quote Originally Posted by Prank111 View Post
    33's
    if going 35" tires do 4.56s or 33" tire 4.30s. oh and since your 4wd you also have to do the front diff also.
    Hes complaining about his low end, but yet he wants to lift it and put bigger tires on it.
    I wasnt aware z71s came with a 4.8 that things gotta be gutless just get you a stall
