Results 1 to 10 of 13
Thread: Can I run a Pro Charger with my cam?
    Jun 2010
    norman,ok
    Question Can I run a Pro Charger with my cam?
    I put a GMPP ASA cam in my '02 Silverado 5.3. Can I run a Pro Charger w/ this eng. or will I have to wait 'till I change over to the 454 stroker?
    Jun 2004
    In a van down by the river- MD
    Boost likes anything, just like nitrous.. Just a matter of what cam it likes more. Put the blower on and let it eat.. And do explain about this 454 stroker :/
    JOHN
    The Garage
    Punch your cam numbers into this thing:
    http://www.wallaceracing.com/overlap-calc.php
    If your value comes out "0" or negative then your cam should be fine for boost.
    Jan 2010
    Cedar Park
    Nice my cam have a value of -1 :-) 224/230 114lsa
    2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
    2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
    Jun 2010
    norman,ok
    http://www.erlperformance.com/gm-ls-...e-short-blocks
    I will pick one of these or maybe the SDPC 440 "the big bull" short blocks. also undecided between short / long block
    There's some others I'm looking at just want to do my reserch first and make sure I get the best one for me and for the $.
    Jun 2010
    norman,ok
    Quote Originally Posted by jetmech View Post
    This link said my cam has an overlap of 11.00
    The Garage
    Quote Originally Posted by mrfister View Post
    Personally, I wouldn't use that cam with boost if it has 11* of overlap, but that's just me. Cam usage, selection, and preference is a VERY divided topic so you will hear many different suggestions when it comes to cams. My cam specs are:
    580/580
    220/222
    114 LSA
    Just to give you an idea of what I believe is a decent boost cam. Hope this helps
    Jun 2010
    norman,ok
    That's what I thought about the cam, so I'll just wait 'til I stuff in the bigger cubes.
    Thanks.
    casey23 Guest
    camshaft
    Listen up cam expert ...... he has boost but it IS NOT a turbo....... So overlap is fine as long as he has enough blower/pulley to make boost .. My shop truck has a EPP blower cam... 232/240 115 600 600 or so.. And it makes over 620 on a mustang dyno on 10psi ....... 2004 LT Ex cab 2wd 5.7L 4l60 10psi and full weight truck..... 11.50-11.70 in the heat on pump gas and NO meth.... I think there are better cams then the ASA cam... but if you own it already then use it.... I like 4-6 degree split with a blower
