Results 1 to 10 of 33
Thread: n20 bottle mount suggestions
    ok me and shifty are working out my future n20 install
    now.. i got 2 10 lb bottles.
    i wanna mount them in the bed.. but im trying to avoid drilin holes in the bed.. yeah yeah.. i can hear all the 'why not's'... but just accept that im anal and dont want to..
    so .. i need ya'lls suggestions, or pics of your bottle mounts..
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    Plainfield, IL
    let the record show.... he's anal by himself...I'm not into that sorta thing
    Nov 2006
    Quote Originally Posted by MidwestSS View Post
    I just installed a kit on the Silvy and also did not want to drill any holes. You can run the main feed line through the frame rail all the way to the back and up and through the boxed openings used to put hooks. My kit came with a 16ft line and it needed to be about 3-4 feet longer to do it that way. If you drill a hole or mount the bottle in the bed but closer to the cab you will not need such a long line. You can see pics of my install on PT.
    60lb Multech II Truck Injectors
    2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
    2004 Dodge Ram SRT-10 - Silver
    2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting turbo
    Better get out the epoxy and double sided tape.
    Honestly, I wouldn't want the bottle anything but bolted down. You're dealing with a container that has upwards of 900psi in it. You could weld studs to the bed floor and mount the brackets to those, time comes you want to get rid of them, just grind them off and a bit of paintwork no one would ever know. Plus with your no hole rule, how are you going to fun the feed line?
    i got ideas on the feel line.. living in the salt region i fear drilling holes in perfectly sound sheet metal.. seen too many of those rust away to well, you get the idea
    Understandable. I drilled 5 holes for the brackets and feed. Coated the bare metal with a rust converter, painted it, then put rubber grommets in each hole. I hope to hell that helps.
