Results 1 to 7 of 7
Thread: bosch 044 in the tank?
    The Garage
    From what I've read, the Bosch 044 is an external pump. I've also heard of people running the bosch 044 inside the tank. How many of you are running the bosch 044 inside the fuel tank and how reliable is it? I only ask because I'm a little hesitant to run a pump inside the tank that is not designed to be run inside the tank. Thanks in advance
    Jun 2004
    george west texas
    we installed ours outside the tank it is not an inside tank pump i dont beleive...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    casey23 Guest
    044
    they make parts screen/pre filter to install them in the tank... most people run them inline cause its easy... but either way u have a good pump ! about time !!
    The Garage
    I haven't upgraded my fuel pump just yet. However, when I do open up the tank again, I want to put a STELLAR fuel pump in that will be able to make some good power and still be reliable. I'm stuck between the bosch 044 and the new aeromotive 340.
    Jun 2004
    In a van down by the river- MD
    I am along with 4 other guys on pt that I know of.. 2+ years, no issues..
    JOHN
    The Garage
    Quote Originally Posted by Mangled03gmc View Post
    Awesome! So apparently the bosch 044 "external" pump works just as well in the tank? Sounds good. I'd like to use the bosch pump becuase of its flowchart
    http://www.jayracing.com/images/Bosc...lbro_255HP.JPG
