For Sale: 2006 2500HD, RCLB, 6.0 LQ4, 4l80E, 4.10 gears, 4X4, 38,500 miles
Located in Houston, TX
$11,900/obo
Very fast truck. Interior and exterior are nearly flawless. Truck was built for street/strip and is very solid and dependable. Only 38,500 original miles. Could be a daily driver if you are OK with an aggressive idle. I have made around 15 passes just to track times at various stages of the build. Has run a best of 11.7 @114mph with a 1.65 second 60 foot (on street tirees). Other than that it has just been my weekend warrior. I can email you a complete list of modifications. Too much to list here but high points include Trick Flow 225 Heads (milled), Comp 227/235/615/620 cam, LS2 throttle body, FAST intake manifold, Nelson Performance tune, Nitrous Outlet plate kit, Walbro 255 fuel pump, Stainless Works long tube headers with Magnaflow muffler and cut outs, GM electric fans, FLT Level 5 4L80E with Yank 3600 stall, 4.10 gears with Detroit Locker, caltracs, rancho adjustable shocks, Centerline rims, PLX wide band air fuel gauge and nitrous pressure gauges mounted on pillar, line lock, and drive shaft safety loop. Truck is a lot of fun to drive and always gets a lot of attention on the street or at the track. I will hate to see it go but moving on to another project.
Dude, WTF!? This is one B/A truck. If the truck is not sold by then, will it be there?
