Results 1 to 10 of 16
Thread: body lift for 2000
    body lift for 2000
    I have a 2000 2500 non HD and would like to add a 1.5-2 inch body lift. Im just looking to easily clear 33's, nothing too crazy. Anyone recommend a kit?
    Dec 2008
    san antonio TX
    my 99 z71 has stock suspension and 33"s without any rubbing. well i should say 32.5" its a 285/75/16 tire. but i bet i could fit a true 33" tire without rubbing. but to play it safe the most you will need is a leveling kit at the most. new torsion keys will give you the extra lift needed. to me body lifts look like crap. new torsion keys will be the easiest way to lift IMHO. heres a link to some leveling kits.http://roughcountry.com/chevy_4wd_99...eling_kit.html
    i would go for the full leveling kit for $190
    Arizona/Utah
    +1 on the torsion keys/leveling>body lift
    Plainfield, IL
    I like body lifts personally. I have one (though I did do it after the suspension).
    Problem with a leveling kit...is 6 days later you'll wish you went larger. A 3" body lift is a nice difference, and when you get bored, you can throw on the 6" suspension.
    If you only want 33's, I'd turn the stock torsion keys the 1/2 turn you'll need to clear, trim a 1/4" off the lower valance and call it a day.
    Quote Originally Posted by lechez71 View Post
    Would ther kit you posted work on my 2500 non hd truck?
    Sep 2010
    middle tennessee
    you dont need a lift to clear those tires, just adjust the stock torsion bars. thats what i did and didnt trim anything. no rubbing under any circumstances. 99 2500 non hd
    99 silverado 2500 4x4 ec lb, lq4 with 243 heads, pace setter long tubes, true duals with x pipe and bullet mufflers, comp 222 224 112 cam, 8.1 truck injectors, 4l80e with 2800 stall, 373 gears, 285 75 16 tires, efi live tune in progress, 350rwhp 360tq, 11.8 average mpg mixed driving
    Quote Originally Posted by aj06bolt12r View Post
    I have my stock bars turned up nearly all the way and the 265's im currently running still rub when the wheels are fully turned.
    Then you have the wrong offset wheels.
