Results 1 to 10 of 17
Thread: Truck Mis-Firing
    Mar 2010
    Midland, TX
    Truck Mis-Firing
    My 08' GMC has been backfiring and hesitating pretty bad the past few days... I have no idea whats going on with it. I have tried HEAT fuel treater in the tank thinking I had water in there... no change. Its been down to 18* or so recently, when the cold weather hit is when the truck started running poor. Today the sucker backfired and blew my CAI off. All I have is a tune and CAI, no major mods.
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    How do the plugs look?
    Mar 2010
    Midland, TX
    I haven't pulled them, the truck only has 40k miles
    Shopping List
    Well pull them, spark plugs will tell you more about how your engine is running than any electronic gadget. My guess is it's too lean or too much timing.
    Mar 2010
    Midland, TX
    I was planning on checking them out as soon as the temp here gets over 20*.... I don't have a shop or anywhere to work out here. Thanks for the input.
    Shopping List
    Same thing is happening to me in this ridiculously cold weather. It's a single damn degree outside right now lol! Plugs are a good place to start.
    ... My guess is it's too lean or too much timing.
    Not to start nothing, so don't take it this way, I just think it's funny to come to this conclusion right off the bat. I would have started out with - history on the truck, any parts changed out, any ses lights maybe?
    Now why would you say there is too much timing? The only way it could be too much timing is by the tune right? I would think I would know better to set the tune up with too much timing lol.
    He would have known this right away after the initial tune install, he would hear detonation going on.
    Seriously though, I'd like to know how too much timing could have happened or caused this?
    Now running too lean, that could be anything, so I won't say you were blaming the tune on that one.
    It could be lean, maybe a bad fuel pump?
    Steps:
    Did you change anything recently?
    Get fuel pressure checked.
    Maybe get the pcm read regardless of ses light illuminating, see if there is something in history.
    Check to make sure the O2's are toggling correctly. O2's don't set right away, maybe it's a semi-bad O2.
    Get the truck scanned and view all cylinder misfire data. See if any of the cylinders are misfiring.
    Those are some of the first steps I'd take.
    I'm thinking a bad o2 sensor.
    lmk,
    allen
