Thread: Oil Pump question
    Crossett,Ar
    Oil Pump question
    This may be a dumb question. BUT here it goes. On the oil pump where the pump meets the block is that a machined face so that there is no need of a gasket or sealer needed where they meet? I cant find a gasket that goes there. No directions I've seen so far have anything about putting anyting kind of gasket except the o-ring on the pickup tube. Need this answered asap guys. Thanks.
    If there isnt a gasket would it be a good idea to put a sealer on it?
    Feb 2008
    Texarkana tx
    You dont need to put anything there. Just bolt the oil pump straight to the block unless you are using a double roller chain.
    2002 RCSB Z71, 409 with stock heads, custom spec cam, vic jr intake, t-76 Q-trim front mount, Tim Frost 4l80e trans, eaton posi, and the list goes on.
    Crossett,Ar
    Thanks man. Thought so but sure didnt want to throw it on without asking and turn out wrong. Better safe than sorry.
