I'm pretty sure the NNBS manifold will bolt right up to an '06, but will all the sensors plug into the harness as well? TB, MAP, etc.? Also, doesn't the NNBS manifold have a bigger 4-bolt TB?
For the tb you'll need the torque rush harness, it's a 87mm vs a 78. Your map sensor will connect right up you just have pull the harness out some.
2004 Silverado ext cab 5.3 Patriot226,Pacesetter LTs, Synergy Tune-TruTrac yankpt3600,Volant Cai, FLT 4L70e level 6
What he said^^^
03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
13' Sierra Denali 2500HD CCSB 4x4
wiring harness that plugs in ur tb
04 rcsb forged 347
Sweet! So everything else is just plug and play?
Wat injectors will you be using? Is urs flex fuel?
