Results 1 to 9 of 9
Thread: Help 96 truck A/C 6.0 swap
    Feb 2009
    baytown, tx
    I can't find a pic of how the frame is cut can someone post a pic of how it's done or a link to a pic?
    Also what's the best motor mounts to buy for a LS swap to the 90's truck? I see there a few options out there. Just don't want to buy the wrong ones!
    I need a computer I have a 6.0 out of a 01/02 HD2500 but I didn't get the computer with the motor. My question is what's the best computer to get? I do not it has a 24 tooth wheel on the crank. Do I just find a computer out of a 01/02 truck with a 6.0?
    Thank for the help
    Spiro, Oklahoma
    I wouldn't bother with notching the frame, its worked for some and not for others then theres the issue with wiring and having custom hoses made. I did it just to find out that the lines would run out right into the a-arm mount, but if you still insist on torturing yourself and trying to do it i'll post some pics. Best motor mounts are the cheapest if you ask me, check ebay I paid around 30 I think.
    Spiro, Oklahoma
    Figured I'd post them anyway, maybe they'll help someone realize what not to do. The first two pics are not mine, I believe they belonged to a member named Nitrous (I think his setup worked).
    Feb 2009
    baytown, tx
    Ok so what's the best way to move the pump up with out buy that small older GM pump? Do they make a relocation bracket?
    Yeah I'm not cutting my frame like that!!! Your just asking for problems if you get hit in the front!!! I know cuz we have to cut the frame on are dirt car for the fuel pump when we move the motor back
    Spiro, Oklahoma
    If you're a good enough welder( I wasn't at the time) and use thick enough metal you shouldn't have a problem with it being weak, if you get hit hard enough for it to make a difference you're f*cked already lol. There is a relocation bracket to use the compressor from an 88-95 truck and I actually have one that I've decided not to use and have been meaning to post it in the for sale section, PM if you're interested.
    Feb 2009
    baytown, tx
    Ok cool... If I change over to the other pump all I have to do is get the A/C line off of a 88/95 truck and it should bolt right up with out having to build a custom line?
