Results 1 to 10 of 34
Thread: How I did 5.3 to nv3500 5 speed
    Dec 2010
    Dyer, Tn
    Cool How I did 5.3 to nv3500 5 speed
    I'm going to post what I did to mate my nv3500 to my 5.3 since I wasn't able to find any reliable info when I did my swap. I bought the flywheel from oreilys. The pilot bearing is an 43.3 mm od with 15 mm Id that is a special bearing that I only been able to find at NAPA. This fits in the end of the crank with no spacer of any sort. The release bearing may be hard to find, but I found one on ebay with this part number 1377c. I used my stock clucth and pressure plate from a 95 chevy truck. With these parts I didnt use any sort of flywheel or pilot bearings spacers and cost less than $100. If you find this useful let me know.
    P/N
    Flywheel Oreilys $60 NFW1050
    Pilot Bearing Napa $20 6302-VSP43
    Release Bearing Ebay $20 1377C
    Clucth Stock
    Pressure Plate Stock
    Dec 2010
    thanks thats what im doing except im going with the 6.0
    Dec 2010
    Dyer, Tn
    Quote Originally Posted by jsisk View Post
    Good deal I hope it helps
    95Z71 5.3 Hotcam 5SPD
    Oct 2009
    I wonder if it would work in a 88?
    Thanks for the info!
    Been looking for part numbers for a while. Just ordered everything at just $100.
    Now to pull the motor and put this in!
    hot & windy
    if you're doing an LS engine to a NV3500, all you had to do was look at my build thread. 4.8 flywheel & clutch kit bolted right on to my 5.3. been running 16,000mi with no problems whatsoever
    99 Sierra - 5.3 / 5spd
    Oct 2009
    What year is your truck? 2wd or 4wd? What size motor was in itfrom factory?
    Quote Originally Posted by tbr89gmc View Post
    P/N
    Clucth Stock
    Dec 2010
    Dyer, Tn
    It's 4x4 with 305 but 350 pressure plate should work also
    What, is, the difference between the throw out bearing listed....than the stock 3500 throw out bearing? I have read you can use the stock one. Just wanna double check before I mate 5.3 and 3500
    I'm still using the stock throw out bearing.
