Thread: Injector plug ins
    Nov 2009
    Tucson,AZ
    Injector plug ins
    I have on 06 5.3 flex, I have 2010 injectors and fuels rails also flex. I need to know the clip size?? I'm going to order 60+ lbs Injectors for a turbo set up. So is it a ev6 or ev1 or multec 2?
    chevyboy.520
    06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
    PRC stg 2.5 5.3 heads Awaiting to go on!
    Nov 2009
    Tucson,AZ
    I want to order new 60+ lbs injectors! What has everyone here bought? What brand? What style or connectors? Ev1 or ev6?
    chevyboy.520
    Apr 2010
    I could not find any Mutlec II injectors larger than stock other than the marine ones.
    If you are going to buy larger injectors you can decide if you want EV1 or EV6 and then get the injector ends you need and you might also need spacers depending on length of the injectors.
    1971 Cheyenne LWB
    6.0/4l80 swap
    2.0/8.9 @ 80 N/A
    1.80/7.8 @ 88 100shot
    Nov 2009
    Tucson,AZ
    I found out that 05 had multec2 and 06 had ev6. So thats why my 06 stock wiring harness plugged right Into 2010 injectors
    chevyboy.520
