Results 1 to 2 of 2
Thread: Power steering cooler?
    My pump just went out, so was thinking of adding a better cooler at the same time i replace the pump(better cooling longer life i hope) can anyone recommend a good cooler?
    Plainfield, IL
    Unless you have huge tires or do any autocross, the factory coolers are plenty. You can get one double the size at autozone for 25 bucks. Any small trans cooler will work.
    Power steering pump isn't like a trans. There aren't clutches that can wear from hot fluid. Bearings typically fail, temp of fluid won't affect that very much. If your fluid was red when it came out, I wouldn't bother.
