Thread: Longtube install
    Oct 2009
    Stephenville,Tx
    Longtube install
    i was wondering if anyone had a link to a good recommended header install instructions. Also i was wonderin what to do to prevent breakin off a bolt and what to do if i do end up breakin one off?
    2006 Chevy ECSB 5.3 - New L33 Motor,CAI, Descreened MAF, Nelson 93 tune, Transgo Shift Kit, servos, 3in exhaust, Borla, pacetter LT's, and ORY, Aeroforce Furture: stall, cam, 4.10's
    Broken Bow, OK
    Soak the bolts with some PB blaster or similar overnight before beginning if at all possible. The bolts in mine all came out pretty easily. That is except for the 2 rear ones that were already broken off. One had the head broken off with threads sticking out, used vise grips to get it out, turned easily. The other was broken off flush, so I left it because I am changing heads soon.
    It really shouldn't take much to turn the bolts, if it seems like you are having to put a lot of torque on them you might want to heat them a bit.
    Dec 2008
    South Carolina
    if you take your fender wells and tires off it makes things a lot easier also
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
