Results 1 to 5 of 5
Thread: 295/40's to 275/45's fix rubing?
    Lawrence, Ks
    Here is my issue. I have a 3/4 drop on my 04 RCSB. I have MB Wheels that are 20X10's. I'm not sure of the offset on them (at work right now). Anyway, I currently have 295/40's on and the front tires hit the fender on bumps. I can see the rub marks on the outside of the tires and they are also getting cut a little bit. Question is, instead of searching for new wheels to buy, do you think it would be worth trying some 275/45's up front? Could that possibly eliminate rubbing issues? Also would that size be ok on a 10" wide wheel? I'll try to find the offset after work. Thanks
    Jul 2009
    RGV, TX
    thats a 20" wheel right?
    Id say the 275 should give you the clearance but im not sure about that being wide enough for a 10" wide wheel. (IMO) I dont think so
    2008 GMC Sierra
    1998 GMC YUkon 4X4
    2007 Kawasaki Vulcan 900 Custom
    Nov 2009
    Tucson,AZ
    315/35zr20??
    chevyboy.520
    06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
    PRC stg 2.5 5.3 heads Awaiting to go on!
    Think you could get away with rolling your fender lips?
    Lawrence, Ks
    Quote Originally Posted by sleeper1500 View Post
    I looked into that a cpl months ago at body shops. No one would touch them cause of the risk of cracking the paint on the 1/4 panel. I can turn a wrench, but I'm not sure I trust myself with body work
