Results 1 to 10 of 12
Thread: Injectors
    May 2007
    Phx ,AZ
    Injectors
    I picked a 03 5.3 last week from the junk yard. I got the motor installed and the injector connects are same as my bosh 60lb injectors. Did they change injector connects in 03 or are these flex fuel injectors.
    Here are some pic's
    Factory 02 injector connections pig tail end
    Truck 2002 Chevy with
    old setup KB turbo kit MP70 LS1
    New setup stock for now
    This is from the lisatahoe pdf from S&P.
    not sure if it helps
    The 2002 LQ4 I grabbed the other day has the flex fuel style injectors, not sure if they even had flex fuel in '02 tho
    -edit
    yes, they did have flexfuel on the 6.0 in 2002.
    answered my own ?
    Broken Bow, OK
    Quote Originally Posted by haveTBIwantLS2 View Post
    LQ4 never came with flex fuel from the factory. Either someone put them in there, or its not a LQ4.
    To the OP. Your first 2 pictures there are flex fuel. The regular injectors were the same all the way through.
    o what the hell.
    now I have something else to wrry about.
    Yah, I was wrong about my edit.
    Broken Bow, OK
    o what the hell.
    What is the part # on your injectors? and it says 6.0 on the block right?
