Results 1 to 10 of 10
Thread: 1st to 2nd hits hard
    Oct 2009
    Stephenville,Tx
    I just had my trans go hd2 and servos installed and from 1st to 2nd gear slams your head against the seat but the rest of the gears shift perfect. would a retune fix this problem or do i need the transmission people to drop the line pressure? it should be stock line pressure
    2006 Chevy ECSB 5.3 - New L33 Motor,CAI, Descreened MAF, Nelson 93 tune, Transgo Shift Kit, servos, 3in exhaust, Borla, pacetter LT's, and ORY, Aeroforce Furture: stall, cam, 4.10's
    Broken Bow, OK
    Put the line pressure back to stock in the tune. How many washers did they put in the servos?
    I have a HD2 and vette servos and with the stock pressure settings in the tune it is perfect.
    Oct 2009
    Stephenville,Tx
    the tune is from nelson and i didnt have any tranny mods when i got it so i figured the he didnt change the line pressure from stock and the tranmission guy didnt change it so i figured it was stock still
    Broken Bow, OK
    How many washers did he put in?
    Gramercy
    my WT does the same thing, i have jacked up line pressure but i added 2 washers or 1 i cant recall and man its hell on the 1-2
    2008 GMC CCSB 6.2/6L80e swap
    Austin, TX
    Did your builder install the 1-2 Accumulator Valve Spring that came with the kit. Mine did the same thing,this's a vid on there about how bad is was, I have to pull the valve body and install the stock spring. If most don't know the 1-2 accumulator valve spring is small about one inch long, that controls the line pressure going to the 1-2 accumulator on the side of the case. I had to install a new spacer plate and not drill out 2nd gear hole, install stock 1-2 accumulator valve spring, install stock accumlator springs with no washers, with stock tranny pressure in tune just to get mine to shift ok, still barks 2nd wot. I think it is my carbon firber band.
    the 1-2 valve spring is 370 or you may have the valve 372 upside down witch would cause very hard 2nd apply
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
    _____________________________________
    2006 2500HD 6.0L Crew Cab 2WD
    Plainfield, IL
    if it's a nelson tune, can almost guarantee he bumped up the shift pressure...unless you asked him specifically not to. Have him set it back to stock.
