Thread: interfacing the wideband
    The Garage
    How exactly does one interface the wideband with the laptop using HPT?? Specifically how do you connect the signal output wire from the wideband to the laptop. I doubt you just jam the wire into a USB port
    Broken Bow, OK
    Depends on whether you buy the PRO interface or not.
    http://www.hptuners.com/forum/showthread.php?t=2924
    The Garage
    So I'm assuming that there is a module you plug the wire into to read the signal from the wideband
    Jun 2010
    This adapter plugs into the side of the interface...
    This is one of the preferred setups for the price...
    http://www.ngk.com/afx/
    http://hinsonsupercars.com/p-946-ngk...eband-kit.aspx
