Results 1 to 10 of 11
Thread: Anyone pushing the limits on Comp 918's or Patriots?
    Question Anyone pushing the limits on Comp 918's or Patriots?
    Since there rated at .600 max lift??anyone running higher lift than what there rated at?bout to get some specs from NP,more than likely ill get the 918' or patriot dual golds......but i want the most potential possible out of this ly6.if not just get the LsR springs :/
    Gramercy
    im running Patriot Extremes and i love them. im not running the max lift but ill take a dual spring over a single spring any day imho
    2008 GMC CCSB 6.2/6L80e swap
    Wasilla, AK
    Quote Originally Posted by keniff View Post
    I agree, dual springs are a good investment. And the little bit of extra seat pressure is nice if you ever decide to go FI.
    Gramercy
    Quote Originally Posted by AKlowriderZ71 View Post
    i dont think ill go FI but i didnt want to chance losing a spring at 6800 rpm bc i didnt want to spend the extra money ya know?
    new style 918s are supposed to be rated above .600 lift if my memory serves me right. I'm running a .59x cam on them, but only have about 300 miles on them thus far. I think it mostly depends on what rpm range you plan on hitting. if you're rarely going to go over 4k and wont go over 6k then 918s should be good, if you're planning on hitting 7k, or you are regularly going up to 5-6k then just spend the extra on a good set of duals. a broken $20 spring can cost alot when your piston gets introduced to your valve.
    s10 with 4l60e and cammed 5.3 on the road!THREAD
    "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.".
    Gramercy
    6800rpm right here
    LS7 lifters
    7.4" hardened pushrods
    moroso high pressure oil pump
    patriot extremes
    .588 .602 lift....i can go bigger but no need im happy with it. i would like a lil more tame cam for DD street races vs my cam coming In really strong about 3500ish
    May 2010
    Lancaster Ca
    I've got 604/610 lift with "new style" 918's no problems yet but i keep it under 6k RPM's. Mainly use it for towing
    Jan 2010
    Cedar Park
    Im running the Comp 918's max lift is .588 and my shift point is 6500... I have over 3k miles on these and no problems at all. Daily drive, racer, moving stuff you name it and no problems.....
    Round Rock, TX
    Why push the limits of something? Makes it sound like you want it to FAIL!!!
