Results 1 to 10 of 11
Thread: 2005 crew cab silverado clone with 6.0 cam and headers, leather, jl audio and video
    needing a heavy duty diesel so the truck has to go. here's what ive got..
    2005 chevy silverado lt3 crew cab. full interior console, gray leather seats with armrests, power driver and passenger seat, heated and memory seats, park assist mirrors with led turnsignals, rear window defrost. profession tint by custom sounds in san antonio. doors and rear wall fully dynamat'ed. custom sounds installed custom box with jl audio 10, jl 6 channel amp powering full range 5.25 in the rear doors and 6.5 separates in the front doors, kenwood touch screen double din dvd player with ipod connetion, bluetooth, sirius radio, adaptor to keep steering wheel controls. huge 0 gauge power and grounds. 0 gauge "big three" upgrade, optima battery, dual headrest dvd players by myron and davis with wireless headphones. interior is perfect and very, very entertaining!
    performance wise it has a new lq9 crate motor put in at 39k. bought new from gm dealer. installed comp xfi cam, lifters, drilled lifter trays, comp pushrods, 918 valve springs and retainers. ceramic coated long tube headers, off road ypipe thats wrapped with volcanic rock insulation, stainless magnaflow exhaust with dual out rear tips. k&n cold air kit, bbk 80mm throttle body, ngk plugs, msd wires, cutom nelson drive tune, trailblazer convertor (2500 stall), transgo shift kit, servo, auburn posi unit with genuine gm 4.10 gears. all mobil 1 oil, 10-30 in the motor, atf and gear oil. power steering system has been flushed using bg products as well as the brake system. front brakes have ebc slotted rotors, new hub bearings, ebc green pads, stainless hoses, rear are stock drums with stainless hoses.
    its got a set of belltech drop spindles up front with bell tech shocks, rear has a bed notch, cnotch, axle flip kit, stock leafs, bell tech shocks, custom 10 degree steel shim to get pinion angle right.
    brand new boss 330's in chrome with new bfg 285/35/22 flame tread kdw tires. when i say new i mean less than 2k miles on them.
    exterior wise its got brand new stock gm lamps all around so it looks fresh and new, silverado ss front grille, genuine gm silverado ss front bumper and all the brackets to go with it, modified buckets so stock fog lamps still work with custom mounts, silverstar bulbs everywhere, painted mirrors and door handles, tailgate handle as well. painted rear "tahoe z71" rear bumper with flush mounted trailer connector, genuine ss emblems in the right spots, gto 6.0 emblem, rubber bed mat, allen head bolts on the bed supports for a flush look. hidden antannae with escalade cover.
    truck has ran 14.06 @ 99.8 at san antonio raceway, and gets 17.2 hiway driving 70-75. its a great compromise of daily driver with great power and looks, and great audio video setup.
    asking 18,500 830-486-9682
    these pics are as of today 7-26-10 6pm. this is exactly as you would buy it!!!!
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
    more pics will be up this evening. truck is getting detailed right now.
    Jun 2010
    West Texas
    Nice ride!!
    RUN WAT U BRUNG!!!!
    Thanks....
    new pics added!!!
    engine pics.
