Results 1 to 2 of 2
Thread: sts stuff
    Blue Springs, Mo
    sts stuff
    Used sts oil return pump -$100shipped
    Used sts wiring harness. Incudes hobb switch for pump (pumps stops working, oil pressure builds up behind pump, which activates a pressure hobb switch and turns on alarm inside cab, Pressure hobb switch for hi/low for pump, and a very loud annoying car alarm buzzard I bought lol. This will fit ext cab as I had to zip tie some excess up when I was using it $100shipped
    Used 95% IC piping from turbo to intake for RCSB. This is setup for a maf. One of the maf piping has a flange for 50mm BOV. Piping runs along frame rail has brackets that bolt up to cab mounts. $100shipped
    Also have the 18ft -3 oil feed line. $50
    If someone was wanting to buy this all I could sell it at a combo price. Thanks Thomas
    2004 silverado rcsb 2wd cammed 6L, 3.42's, Hydroboost swap, 4l80e w/hd-2 and yank 3200, twin intank pumps, 60lb injectors, trick hot pipes/MP T76
    Blue Springs, Mo
    IC piping and harness sold. Pump still for sale.
