Results 1 to 5 of 5
Thread: Piston and rod Question
    S.A. Texas
    I have some flat top mahle pistons that call for a 6.100 rod and I also have some 6.125 eagle rods. will that .025 longer rod make it impossible to use the two together. I know it sounds like a noob question.
    Round Rock, TX
    Longer rod is going to push the piston up higher in the block. You need to check and see what the deck height is for those pistons with a 6.100 rod. It could push them out 0.010 or it could be 0. The 6.125 rods could cause some clearance issues and increase the compression quite a bit. Thats why they make different compression heights for different rods and pistons.
    S.A. Texas
    yeah that is what I was thinking. I wasn't sure. I will look in the deck height. I would still like to run the flat tops with the 317's and run 15psi. I think that would make powerful combo. Thanks for the input and info Jon
    S.A. Texas
    Got me a straight up trade for the rods i need in a 6.1 length woo hoo Lets just hope the 10.6:1 compression isn't too much for 12 psi.
    That should be a fun combo
