Results 1 to 10 of 11
Thread: WTB Stock intake + tb and z06 valley cover.
    Well like an idiot I threw my intake away thinking it was a damaged one that I have. I plan on selling the TBSS intake and Nick williams 92mm throttle body so I will need an intake first. I'd like an intake that doesnt have the egr hole. Stock tb or shaner ported would be great.
    Plainfield, IL
    what's the difference between stock and z06 valley?
    Z06 has a vent in it.
    casey23 Guest
    I may have a stock intake... but no TB
    Houston
    ive got my stock lq9 intake and tb no egr port on it
    Apr 2005
    I have a almost stock TB. I drilled it when I got fed up trying to get my IAF right with my cam in my old truck.
    I actually swapped my polished one out, but used the stock blade, so this one is a stock TB with a drilled blade. If interested, let me know.
    2000 RCSB Z-71 6l swap 12.8 Gone but not forgotten
    2008 CCSB "tow truck" Slooowwww
    1999 RCSB "WRK TRK" 4.late but getting there.
    Aug 2005
    houston TX
    i have a stock lq4 intake no egr and a ported dbw throttle body
    03 1500HD 4x4 6.0 on 33"
    K&N intake, Pacesetter LT, 3" true dule orp, Magnaflow, Comp cam 237 242 .603 .609 112, Patriot Gold springs and Ti retainers, stock ported heads, ASP Underdrive pulley, 42# injectors, 160 tstat., 05 E-Fans, Nelson Fan Harnas, tb bybass, MSD wires, NGK tr55, Ported tb, Transgo HD2, yank 3200 conveter, HP tuners, Walbro 255, 4.56s
    Gimme a couple of days A guy I know thinks that he can make this combo work for me. So I am going to wait till he tunes on the truck. . . . . .
    Spiro, Oklahoma
    I've got an intake from an 05 5.3l, has rails and injectors. It did have the egr hole but its been plugged. I can get pics if you want. I'll let it go fairly cheap as I have no use for it.
    GLENDALE,ARIZONA
    I have the Z06 VC and Ported CD TB buy only have an ls1 intake...
