I replaced both knock sensors, deleted the old code and now I get this P0327!!! Help!!!! What did I do wrong?????
Did you replace the knock sensor wiring harness?
I didn't replace the harness!! I cleaned them up and put sum electrical grease on them!!
Ok! I went back in and replaced both knock sensors and pigtail harnesses!! Still throwing this damn code!!! Help!!
double check the wiring make sure the connectors are good and the prongs are in good shape, autozone is also known to having bad sensors or a batch of them.. might wanna look in the a oem gm sensor.
Simple: 408 on steroids!
single digits coming soon!
have yet to replace mine but i should
2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
