Results 1 to 10 of 14
Thread: Timing Chain Question
    Mar 2010
    houston,texas
    well i have put my lq4 back together and bought a beefier ls2 timing chain for it but there seems like there is alot of slack in the chain and i was wondering if this was normal if not what should i do
    2006 silverado crew cab z71 6.0
    Nelson Tuned
    LT
    285/75/17 bfg mud terrain km/2
    TSP 220
    Pittsburgh, PA
    LS2 chain with Ls1 sprockets does have alittle bit of slop
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Mar 2010
    houston,texas
    so should i get a ls2 sprocket or will i be okay with my ls1 i dont want my timing to be off or anything to get messed up
    Nelson Tuned
    LT
    TSP 220
    Tyler, TX
    probably best to get the ls2 cam sprocket, its meaty to say the least, and if you wanted, you could switch to the front cam sensor, no idea why though. . . but yeah, get a sprocket
    www.tjc.edu
    Mar 2010
    houston,texas
    ok do you know if its the same 3 bolt
    Nelson Tuned
    LT
    TSP 220
    Round Rock, TX
    NO reason to switch. The cam sprockets are identical. They both measure .210 thickness. And the gears are identical..
    Mar 2010
    houston,texas
    so should i just leave the chain the way it is cause i dont want to much slack in it..
    Nelson Tuned
    LT
    TSP 220
    Round Rock, TX
    Quote Originally Posted by silverado120 View Post
    It will be fine. Gunna have the same slack if you change cam gears or not. Waste of money.
    Mar 2010
    houston,texas
    ok and what if i put a damper on it i dont think it has holes for one but was just curious
    Nelson Tuned
    LT
    TSP 220
    Round Rock, TX
    I don't see a need for one. Unless your reving over 7k and making alot of power..like 600+hp
