Results 1 to 10 of 10
Thread: Stupid head question...
    Plainfield, IL
    Looking for a set of heads for the new engine setup. Looking at tanz post on different LS heads.
    243's seem to be the most sought after head. They have a combustion chamber of 64.45cc.
    706's are a dime a dozen, and have combustion chamber of 61.15.
    Wouldn't putting a set of 706's on any engine bigger then a 5.3 net more power then 243's because it would have a higher compression ratio?
    I have been looking at ported 243 heads thinking I was going to gain power, but realistically, I'm going to lose compression because my 5.3 is smaller then a 5.7, so is it possible these will LOSE power over my stock crappy 706 heads? Or will the bigger port volume more then make up for the lack of compression? I'm looking for a set of N/A heads, was hoping to end up with a 10.5 or so compression ratio.
    Plainfield, IL
    anyone?
    Nov 2009
    chicago, il
    I would deck the 5.3 heads and port those. You'll retain compression, and get them to flow very close to ported 243 heads if not the same as 243 heads.
    Plainfield, IL
    Ya, I bought a couple "how to build ls1" type books, and have been doing a bunch of research. Think that's where I'm going. I'm just worried about having my heads worked, that something won't be right with clearances. I am not pulling engine out, so it will be hard to check everything myself. Was trying to get something tried-and-true to be safe.
    Nov 2009
    chicago, il
    I port cylinder heads, if you want something that will work without worries and perform very well.
    Hey truckin how much do u charge to port a set of 5.3 heads? Can u mill them too?
    Plainfield, IL
    pm sent
    why not just P&P some 862s, mine seem to do pretty well.
    Plainfield, IL
    ya...that's the current plan. Or just breaking down and buying the patriot 5.3 stage 2.5 heads.
    Problem is I want to tear apart/rebuild in a weekend. Don't want the motor apart for weeks, so I'd need to find a cheap set of 862's to have built before I tear into motor.
    ahem!!, i might know a guy
