Results 1 to 10 of 10
Thread: springs, gauge pod, and tuner 4 sale
    Oct 2009
    huntington indiana
    first up i have a pair of hotchkis 3" rear lowering springs i had on my 04 avalanche for less than 2 weeks, part # 1924, they will fit 200?-to 2006 gm suv's with rear coil springs $100 obo shipped
    next i have a new auto meter column mount gauge pod part #15007, it will fit 2000-2003 trucks and some suv's?? i bought it new and it wouldnt fit my 2004 avalanche, im asking $35 shipped
    and i have a jet dynamic spectrum tuner that i never used, it wouldnt work on my hp laptop running 64 bit vista (i dont have the right comm. port) it still has 4 licenses and i still have all the papers and box, it will tune 99 up gm cars, truvks, or suv's with a v8, check their web site to make sure it will work- jetchip.com , im asking $350 shipped-SOLD
    procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
    and ya it will beat a hemi.
    Oct 2009
    huntington indiana
    more for sale
    airaid cold air with pre filter (maf NOT included) $175 shipped
    and 17" avalanche wheels with 265/70/17 goodyear fortera tires, great tread, only used 3 months or so. local pick up, or?
    Broken Bow, OK
    Is that gauge pod meant to fit over the existing piece or replace it?
    Oct 2009
    huntington indiana
    i think it fits over it??, i have not even opened the instructions, i took it out of the box and that is as far as it got
    Oct 2009
    huntington indiana
    here is some more info on the jet tuner.
    Dynamic Spectrum Tuning:
    DYNAMIC SPECTRUM TUNERS - Designed for the performance enthusiast who wants total control of their vehicle's programming, the JET Dynamic Spectrum Tuner is a powerful tuning package. JET’s DST software provides you with the tools needed for precise performance tuning using your laptop or PC. Use of this software will give you the ability to modify virtually every aspect of the vehicle’s programming.
    Stock programming from the vehicle is initially downloaded and saved to your PC using the supplied JET interface cable that connects to the vehicle’s diagnostic port. The stock programming can be reloaded to the computer at any time to return the vehicle’s ECU to its original state.
    The comprehensive, easy to use software allows extensive modification to the vehicle’s software. This allows control of fuel and spark tables, speed and rev limiters, transmission functions, torque management tables and many other functions. Modifications are made using detailed table and graph views for easy and accurate parameter editing. Your modifications are saved as a new file and downloaded to the vehicle’s computer.
    DST Gas Part # 14005 Programming Options Include:
    * Fuel parameters including power enrichment and volumetric efficiency
    * Ignition tables including spark advance versus load, knock retard and more
    * Transmission shift points, shift pressures, and TCC apply and release
    * Diagnostic tables including fuel and air, ignition and emissions controls
    * Speed calibration tables to correct speedometer and shift points
    * Idle controls, fan temperature settings and torque management tables
    * Raise or lower speed and rev limiters
    * Disable factory diagnostic trouble codes
    DST part number 14005 will program the following vehicles:
    1996-2000 GM Trucks & SUV's with Vortec 4.3, 5.0, 5.7 & 7.4L
    1999-2006 GM LS1 Trucks & SUV's with 4.3, 4.8, 5.3, 6.0 & 8.1L
    2002-2005 GM/Chevy Envoy & Trailblazer 4.2L
    2002-2004 Oldsmobile Bravada 4.2L
    2007 Sierra/Silverado Classic w/ LS1 4.3, 4.8, 5.3 & 6.0L
    1996-1997 Camaro, Firebird, Corvette & Impala SS LT-1
    1997-2004 Camaro, Firebird & Corvette LS-1
    1998-2002 Camaro, Firebird 3.8L
    2004 GTO LS1
    2004-2005 Cadillac CTS-V
    DST part # 14005 will allow you to program 4 different vehicles from the list above. Licenses to program additional vehicles can be obtained from JET directly for $100.00 per vehicle.
    New! DST Gas version 1.49 is now available. Contains support for several 1998-2005 GM passenger cars. Check application listings for your vehicle. Download the update from the products section on the homepage or click here to download now.
    Oct 2009
    huntington indiana
    sale pending on the dst, any offers on the rest????? i forgot to put obo. on every thing.
    Oct 2009
    huntington indiana
    BuMp
    Oct 2009
    huntington indiana
    ttt
    Oct 2009
    huntington indiana
    airaid intake sold
    Oct 2009
    huntington indiana
    wheels pending, any offers or trades on the gauge pod or springs?
