Results 1 to 2 of 2
Thread: Noob in Nebraska
    Apr 2010
    Noob in Nebraska
    Just came in today, my name is Joe. I've been thinking of doing a 5.3 S-10 for a while. I'm in my final quarter as a GM ASEP student in Milford, Nebraska. Within six months I'll be ASE certified in A1-A9 standards. And hopefully within 2 years I will be GM World Class.
    I'm still in the thinking stage of this, but here it goes:
    -Later body style S-10, single cab, possibly extreme, but just a thought.
    -5.3 AFM motor, LH6 Vin M engine (Active Fuel Management, DOD)
    -4L60 with stall converter
    All electronics that I can make work properly, probably use the BCM, and run the cluster from a donor vehicle. Best case cinario would be to find a wrecked 1500, envoy, or a trailblazer that I can rob all the needed parts from.
    I figure with AFM, and a much lighter vehicle, the ECM will allow the engine to go into V4 much more often, and pull pretty decent MPG's with it.
    There's going to be a lot of research for this project, and hopefully I can pull a lot of it from this forum, and a few others.
    Couple that come to mind:
    -Rear end options, 1500 would obviously be ideal, stronger, locker readily available.
    -LS series intake
    -Fuel lines and tank, maybe fuel cell
    -possible to make ABS functional with the S-10 hubs
    -Use of 1500 steering column, and hopefully the steering wheel controls
    -Power steering?
    Any thoughts or ideas would be great!
    Thanks!
    Welcome . . . . . .. . .
