Results 1 to 2 of 2
Thread: front mounted hot parts
    May 2007
    Phx ,AZ
    I am selling the hot side piping from my front mount turbo setup. This kit includes:
    -Crossover pipe that bolts to stock driver's side manifold
    ----contains an O2 sensor bung for the driver's side O2 and a flex joint under the transmission
    ----will fit 2wd or 4wd...there is plenty of clearance for a front driveshaft
    ----bolts and gasket for crossover-to-stock manifold are NOT included
    ----bolts and gasket for crossover-to-log manifold ARE included
    -Log manifold on passenger side
    ----This is the Cmotorsports manifold that Parish and Thunder550 used to run on his truck
    ----has a T4 flange
    ----has a bung welded on for EGT probe just below the turbo flange
    ----turbo flange bolts and gasket are NOT included
    -Downpipe and mid pipe to bolt up to stock style cat-back
    ----contains 2 O2 sensor bungs (one just below the turbo outlet for stock passenger side O2 sensor, and one further back for a wideband)
    ----downpipe-to-turbo connection is a v-band (v-band clamp IS included)
    ----old crank case venturi bung just behind turbo outlet has been brazed shut
    ----mid-pipe contains a 3" cutout pipe with cap, as well as a flex joint
    ----bolts to connect downpipe to mid-pipe ARE included.
    ----bolts to connect mid-pipe to cat-back are NOT included
    -JGS 44 Magnum wastegate included
    ----v-band connection to manifold and downpipe
    ----v-band clamps ARE included
    ----light (4 psi) and heavy (8 psi) spring are also included. Heavy spring is currently installed.
    I am asking $1100 shipped for this setup. I prefer NOT to use paypal for a large purchase such as this, unless the buyer agrees to pay the fees. There should be no fabrication needed on the hot side. This is all bolt-on and ready to go, and as stated above will fit both 2wd and 4wd models, any GENIII fullsize truck. The A/C line coming from the dryer will need to be rotated slightly to clear.
    Truck 2002 Chevy with
    old setup KB turbo kit MP70 LS1
    New setup stock for now
    May 2007
    Phx ,AZ
    bump to top
