Results 1 to 8 of 8
Thread: fuel lines
    Jan 2010
    Lubbock, Tx
    fuel lines
    Well doing a 5.3 swap into my 73 swb...my plans were to re-do all the fuel lines, but it was suggested to me that since im using a return style motor i could reuse the stock fuel lines up to the motor with the exception of mating them to the fuel rail then just make my own return line.....any one got any input?
    00 Z28 just another cammed, stalled and sprayed LS1
    95 GMC sierra ext. cab
    Project : 73 chevy swb
    Oct 2003
    nope.
    Nov 2009
    Fort Smith, Arkansas
    Will your stock lines handle the pressure? I figured since it was originally a carbd setup that you don't have fuel injection fuel line. Unless there's something you aren't tellin us.
    Cromwell, CT
    perhaps you mean the other way around? make a new pressure line and use your old line for the return? That makes more sense.
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Aug 2006
    I used the stockers on my 86...but I am running returnless fuel rail.
    I used the vette filter/regulator mounted right inside frame opposite fuel tank, went an to adapter to use stock fuel line, then where it ends up front, adapter to an to get to fuel rail.
    86 C10 6.0/4l80e
    Jul 2009
    Brownfield tx
    fuel lines
    My plan is to use 3/8 and 5/16 fuel/ brake lines from napa bout a dollar a foot and then go to the salvage yard and swipe the hoses and about 6 " of the tube off a donor truck flare the tube and mate it to the new fuel line lot cheaper than 40 bucks a pop aremotive an ends to make the swap
    Jan 2010
    Lubbock, Tx
    Quote Originally Posted by pcmcobra View Post
    Cool thats what i was looking for!!
    Round Rock, TX
    JUST A FYI. The return line sees the same pressure as the feed.
